I have had a metal on metal rubbing sound coming from the engine somewhere now for a while.It's not there while on tick-over or while normal driving but if i put my foot down a bit then you can hear it until it changes up a gear even with the windows shut.
I had a look under the bonnet yesterday and the small top pully wheel where the adjustment bolt is has got some slack in it so would this cause the metalic rubbing sound that i have been hearing.
I don't want to tighten the belt wheel up until i know whether there is meant to be some slack at all on it....T.I.A
