Anti roll bar rolling!!
  • Anti roll bar rolling!!
    Well the other day I noticed that one of my drop links on the end of the rear ARB had snapped, the nut on the top had just been pulled off it looked like, so I decided to replace both, however once I removed both the ARB just flopped down, I guess this meens that the rubber bushes are trashed,
    So please can you help, where is the best place to get some new ones from?
    what I really want to know is should I got with procomp urethane ones 8.95 for the set. OR roughtrax rubber ones 5.50 each.
      i would go for the set from procomp as it will work out cheaper then the others
        hehe, oops, I ment to tell about that!!
        They arn't that tight in the bushes, the weight of the bar will make it flop over. Having said that, if you can wiggle it around in the bushes then its best to replace them.
        Urathane bushes with be firmer and look bling cos they are orange, the rubber flexes more, but you'll probably never notice the difference in reality.
          cheers guys,
          I might have to hold onto the screw driver I found today!!! Tony!!!!
          Dont worry I might be popping past your place in the next few weeks so will drop it off then!
            cheers guys,
            Hehe my friend found pliers in hers the other day - no wonder he's always buying tools!!
            When I broke the drop arm on my ARB in Cornwall we just tookthe whole thing off and left it off!
            Linda
            www.4x4toys.co.uk
