Hi all.
Any advise most welcome as newby to the Surf, bought a 98 3lt in Sept from a import dealer but done over 9 thou miles since then, had it serviced by local garage but now hearing a noise from the front end.
The noise is almost a grinding / whirring noise that is louder at low speeds but does not favour any side when cornering, it has progresivley increased in volume over the last 2 thou miles.
Does anyone know any problems with the front diff, wheel bearings or half shafts to check befor I start changing bits?
Thanks in advance
Fish.
Thanks in advance
Fish.
