In an effort to find the clunk from the rear of my Surf, I've spent the best part of the morning crawling around on my driveway. I posted a thread about this clunk happening when I make a right hand turn & most of the replies suggested the rear ARB. I now know that none of the mounting brackets have sheared & the bushes look to be in good order, at least on the mountings to the axle. I thought the O/S drop link top bush looked a little suspect so I put a spanner on it to see if there was the possibility of tightning it up & to my surprise, the whole link rotated quite easily until stopped by the ball joint at the lower end of the link. Is this normal? I would have thought that any means of attaching an ARB would require a rigid mounting, not something that rotates. Any bush replacement I've done on other vehicles ARBs has usually required a bit of effort to release the attaching nuts & bolts. The nut itself wasn't loose, in fact, the nut looks to be fairly well rusted to the thread at the top of the drop link but I'm sure some duck oil will free it up. I'm also unsure as to why there is a ball joint at the bottom of the link. I always thought that an ARB relied on its' own torsional stiffness to resist the rolling effect & it seems to me that putting a ball joint at either end kind of defeats the purpose.
Anyway, anyone else have any idea if this drop link is supposed to be able to rotate in its top mounting? BTW, the N/S one also rotates, but not as freely as the O/S one.
