When you switch on the air con at tickover the revs rise to allow for the extra drag on the compressor,it may negate the extra you have from the intercooler.
http://www.alcohol-injection.com/ is a good place to start,there kits are good prices,the idea behind using water/meth is that the fluid asborbs heat as it is injected into the inlet manifold-and the good thing about using water/meth is that the water takes a lot of heat but quite slowley and the meth takes less heat but asborbs it more quickley,so you end up with the best of both worlds,also you can have a pressure switch so it only works on boost and not all the time.
Ray
Ray
