just had one of them nasty cheap ebay heads crack on me after two weeks, does any one know if the milner heads are o.k?
ebay cheap head
not sure about the milners heads but i would go for the Stevo head at least you know your getting something that will lastOriginally posted by terry edgleyjust had one of them nasty cheap ebay heads crack on me after two weeks, does any one know if the milner heads are o.k?https://www.facebook.com/groups/henpals/
Or....
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=27739
I can't say 100% that it's the right one but that's what I've always understood.
Not at all would be good for meOriginally posted by stormforce1067with or without tongues
I'm just glad someone off the forum bought it. I was watching it and considered buying it myself (and sticking it up for sale here) when I didn't recognise the bidders. Good job I didn't - there could have been an unfortunate bidding war there.
I just hope I'm right about it being the 'modified' 2.4. Still, 62 quid for a head is a bit of a scoop anyway.
Terry
A problem with cooling system must have contributed to cracking original head and the cheap ebay one - surely ?
so will a new head fix that?
have you checked cooling fans, radiator, rad cap & thermostat ?Landcruiser Colorado
Sub. Forester
hi andy i bought it with the head off, rebuilt it with the ebay head and found that the thermostat was jammed shut, replaced it and all was fine for 2 weeks then bang, still the 2.8 head is on and all is good fingers crossed, thanks again sancho.Originally posted by andycookTerry
have you checked cooling fans, radiator, rad cap & thermostat ?JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
Still though, HAVE you replaced or checked everything else related to theOriginally posted by terry edgleyhi andy i bought it with the head off, rebuilt it with the ebay head and found that the thermostat was jammed shut, replaced it and all was fine for 2 weeks then bang, still the 2.8 head is on and all is good fingers crossed, thanks again sancho.
cooling system? An uprated head won't make a jot of difference if you haven't
checked and serviced your cooling system. The new head will be far more
resilient. It isn't, however, indestructible.
