went about fitting new brake drums today and managed to fit one but just wanted to check that what I did was correct: removed old drums, adjusted the star screw adjuster the wrong way first by letting the shoes move out even further, then screwed it the correct way until the shoes were retracted just enough to put the drums on, after every little adjustment of the star screw i gave the handbrake cable a pull at the rear axle, then put drums and wheels on and then worked the handbrake a couple of tmes....then had to bleed the brakes as they were spongy, was this the correct procedure? i'm not sure if the shoes are self adjusting or not, how can I tell...should I be disconnecting the handbrake somewhere while adjusting the star screw..do brakes always need bleeding after this type of adjustment? sorry i know it would have made more sense to ask all these questions before starting the job!
ent
1989 2LT
ent
1989 2LT
