For a few weeks now I've been scratcing my head about my 96,3rd Gen,5 gear manual surf being stuck in 4wd. I thought the car might just be getting confused and actually 'not' be in 4wd, but you can feel it on cornering.
I was told to check the vacum hose, but the only hose to the electric motor connects to the top of the gearbox which seems ok. I have taken the motor off and checked it and all seems to be working ok.
I'm worried it may be a gearbox problem but I want to see if I can at least find the problem before it comes to suggesting that the my local friendly garage!
Any ideas would be appreciated because something tells me that it's not just the increased consuption I'm going to have to worry about before this is diagnosed and fixed.
As far as I know, the 4wd is not controlled by a vacum system like on the 2nd gens, but is controlled by an electric motor which is, in turn, controlled by a rotating disc within the motor unit at the back of the gearbox. The disc has metal circuits on it which come in to cotact with brass pins which seem to tell you what the positiion of the disc is. This seems to be what controls the lights on the dash and the relays on the system.
Please help if you have any ideas
