My SURF has just failed the MOT because of a seized LSPV. I stripped and cleaned this out and it now appears to be free.
When pressing the brake pedal the plunger moves out, but only about 4 mm. Is this the correct amount of travel to be expected, looking at the size of the plastic rod guide fork there is room for a lot more movement on the plunger?
It appears that the transverse rod restricts the movement of the plunger when the vehicle is heavily loaded, if this is the case how is this rod assembly adjusted?
![Mellow](https://hiluxsurf.co.uk/core/images/smilies/mellow.gif)
