Front Axle
  • Front Axle
    Hi Guy's can anyone tell me how much it would be for a second-hand front axle thanks Ron.
    Hi Ron, What is wrong with yours???
    Do you want the diff or the drive shafts??
    I might have one that will fit your truck.
    Jon
    I'm a custard donut monster
      When looking around for my replacement I was quoted approx 511.00. Ended up by brand new for 987.00 from toyota. Had to wait 3 weeks to be shipped from Japan
      http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=26376
      Gaz
        Like Jotto said, what part? you don't have a front axle as such on a IFS surf, There is a the diff unit, then on one side the ADD unit (which does the 4wd selecting) then a pair of drive shafts and finally the hubs.
        If you're replacing the diff you need to get the same gear ratio as the rear for the 4wd to work.
        All the parts won't usually be broken, you just need to isolate which bit.
