Hello all, looking for some advice
I have a 3.0 diesel (95) and having thought the ride was a bit weird and having some strange noises I've done some investigating.
I've discovered the anti roll bar bushes need doing, (no problem there) also the body height is about 1.5 inch lower at the back also about 1 inch lower on the driver side (front and rear) all measurements from the centre of the wheels to the wheel arch.
I've also found if I turn left quickly or turn left up a sloping corner I get a LOUD twang at the rear that sounds like a drums been pounded.
I cant see anything loose or broken apart from the play in the anti roll bar bushes
finally the front passenger side wheel is leaning out at the top about 1inch more than the other.
I would welcome any comments from the more experienced surfers for tips on rectifying these problems.
cheers chaps (and chapesses)
Brian
Brian
