Just got in a 1995 SSR-G 3.0 Diesel, from Japan this month, and have run into some problems that have totally disheartened me
, could anyone help me?:
1. The steering is very stiff when at a standstill or low speeds, its ok once the vehicle is running. i opened the cap with the engine running and the fluid literally squirted all over the place. what's wrong?
2.the mileage shown is 43000km but the timing belt indicator is on. have they messed with the mileage of can there be some kind of error.
3.is the changing of the timing belt a very tricky endeavour or can a moderately skilled mechanic do the job?
I have checked with the dealer here and he wants to charge me a bundle for the job.
4. When i went to the dealer to check out the replacement of the timing belt, he advised me to change the tensioner as well as the bearing associated with the timing belt , with out even inspecting the vehicle. should i take his advice, or is he just a commission hungry ingrate.
SOMEBODY HELP, PLEASE.
, could anyone help me?:1. The steering is very stiff when at a standstill or low speeds, its ok once the vehicle is running. i opened the cap with the engine running and the fluid literally squirted all over the place. what's wrong?
