silly question I know but can anyone tell me the tyre pressures for my 1990 ssr ltd surf many thanks Graham
tyre pressures
Originally posted by macgrahamsilly question I know but can anyone tell me the tyre pressures for my 1990 ssr ltd surf many thanks Graham
Got a 1990 ssr ltd as well and sticker on door recommended 28psi but I found the tyres squealed to much at this pressure.
Now run at 33psi but as suggested above anywhere around this pressure is OK, just down to how you like the ride/handling etc.
Good to see the Herts mafia is growing strongerSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
Originally posted by GreeboJust as an aside to this, do any of you adjust the tyre pressures when you go off road? if so what to?
Not to date I haven't, Roger (Gamedawn) does, I think he lowers his to
18psi or there abouts, he runs BFG AT's. In hindsight at the last pit meet if I had lowered my pressures (31 x 10.5 x 15 BFG MT's @ 33psi) I would probably have made a bit more light work of some of the hills.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
You can generally go down to 12-15ish, before you start to have trouble with the beads coming off when pushing on the sidewalls in ruts. If you run beadlocks then 8-10 or lower for rocks, will get you amazing grip.Originally posted by GreeboJust as an aside to this, do any of you adjust the tyre pressures when you go off road? if so what to?
