got some (of a 2nd gen), but im a bit too far from you, near you there is JAP4X4 07759272270 sure terry or his boys will help you with that
retro fitting a rear heater
heater switch
The 3rd Gen does not have a rear heater switch up front, it's only the one on the back of the console box.Originally posted by Karma Supra View PostI thought about doing this conversion before on a 3rd gen (you didn't specify)
There is also a fan switch up front, and the floor carpet is a different shape.
I kind of lost interest because it got warmer again... but I've always hated how you are melting at the front, and the back is cold!
Not such an issue now I have remote start
I'd be interested to see how you get on! I've heard that the pipes can suffer from corrosion...
I'm pretty sure the carpet will accept the heater - at least I hope so!
I already have copper pipe ready to replace the always corroded twin pipes!
UPDATE: I have heard that fitting copper pipe can cause galvanic corrosion of any aluminium parts (head, radiator etc.) Has anyone any experience of this having fitted copper pipes to the rear heater?
