OK so I need help, has anyone swapped out their 2.4TD for a 3.0TD and if so what little things need to be done? I just bought a 3.0TD surf with rollover damage and want to swap the engine into my 2.4. Do the engine mounts require fabricating or does it swap straight in? Any help appreciated. Cheers
engine conversion
You will need to change the wiring harness and control units, ie ecu etc and obvious things like the radiator, starter, alternator, exhaust etc. As for the engine mounts, just leave them on the 3.0L then should slot in ok.
And welcome to the nuthouse mateLast edited by Wild Thing; 7 September 2006, 07:37.If it aint broke dont fix it
Hi m8, im no expert on this matter, but i know it has been covered before.
the genral concensus is that its more hassle than its worth, but is possible. it may be worth doing a search and see what it brings up.
oh and welcome m8...CHEERS JOHN................
Its not a straight swap you need to change over the wirring loom and the engine mounts do need some fabrication.Originally posted by nastysmurfOK so I need help, has anyone swapped out their 2.4TD for a 3.0TD and if so what little things need to be done? I just bought a 3.0TD surf with rollover damage and want to swap the engine into my 2.4. Do the engine mounts require fabricating or does it swap straight in? Any help appreciated. Cheers
Have a look on this site
http://www.toyotasurf.asn.au/techsite/enginetrans.htmI'm a custard donut monster
