Failed the mot today on both outer driveshaft gaiters.
Reading through the posts it seems like it will take me 5 hours a side to do the gaiters which is time that i dont have.
My brother in law said he did his with a kit where you glue the gaiter together and it is still going strong a few years later.
Would you recommend doing this, or has anyone actually done this themselves.
The garage quoted me £210 to do the job, which seems a bit excessive, the only benefit from this would be no re test fee.
" the put on you split boots!! if you do decide to use the split boots there are two things i would advise on !!
