Originally posted by Cornishman1
of adding an extra cooler before you know your cooling system is in good shape,
you may end up masking a problem which will get worse eventually. An ATF oil
cooler is an extra perk for towing, but get the basics sorted first.
With the rad, a pinhole definitely won't be helping. You can either repair it with
solder and a propane/butane blowtorch, or take it to a rad specialist for repair.
With regards to the viscous fan, just do a search for viscous fan on the site.
Believe me, there's more info than you can shake a stick at.
The old pictures are back as well. We've just lost the new ones now.
