Noise......bearing?
  • Noise......bearing?
    recently ive started getting a squeeling noise, mostly in first and reverse gear, also a tweek of a noise when i let of the accelerator in second gear
    all other gears there is no noise at all, truck drives fine, i think its possibley from the centre propshaft bearing, does this seem reasonable
    how easy are they to replace
    also does the 2.4 exhaust fit the 2.8 as no one can say yay or nay for definate
    thanks
    Mat..
    All things Lexus...ask moi
    no-one...?
    Mat..
      No idea on the bearing but pm me your chassis## and i'll try running it through the EPC to cross reference your exhaust part no.
      =SOLD UP!=
        Originally posted by Monster-Mat
        no-one...?
        Whereabouts is the squeal coming from?
          thanks ill pm over the chassis numbner this evening...
          regards the location of the squeal its hard to say as it only does it when in motion.....but.....i think its coming from the centre prop bearing
          Mat..
            well i sorted the exhaust, managed to get a complete new one for a great price, while i was under the truck, i noticed the gearbox mount had completely fell apart, more than likely the cause of the " fail" of what i suspect is the centre prop bearing.
            so next thing to be replaced is the centre prop bearing, hopefully that will solve the squeal........
            still not found out the "how to change bearing" info, so i think its gonna be a case of suck it and see, unless some knows.....
            Mat..
