Once I get over to where it's parked (probably Monday) then I'll take a quick piccy and post it on the forum so you can have a look yourself. Didn't take more than 20 minutes on the bench to mod!
cheers mate,
i went to the local breakers but no joy so will keep looking,will try and find surf replacement or landcrusier as well as the ford,so ive got three chances then,regards dan
cheers mate,
The chances of finding a LC or Surf in a local scr*pyard are small, believe
me. Try a motor spares. Apparently, the original Ford primer head are
a bit of a sod for leaking, so many motor spares sell a compatible unit.
Those types of filter are also in many other makes of car. I've seen about
seven different minor variations, usually filter canister size more than
anything.
About half way down, the diagram with the pipe highlighted in red. Yours
will be somewhat different, but the general idea will be the same. Check
all the hoses around that area to make sure they are on tight and not
cracked.
looked at pipes today,had a pull about,had big torch and could not see anything wrong!not sure if its the same hose as in the picture but the only one i could find like that was on the air filter one that gos over the top of engine,that one has a trap/filter on it.
thereare two from the single story spaceship and 4 from the double high spaceship.
where to look next?
Further to my exploits of last week and the seeming 100% fix of the situation, we again suffered some intermittant (although short) bouts of power loss again. I'd decided enough was enough, and I dropped the tank out to take a look. to my suprise there was so much c**p and debris floating around that I cleaned the whole thing out especially around the feed to the fuel line filter. Everything seems to be a-ok again.
If the problem is not vacumn hoses as otherwise suggested then I reckon it's got to be fueling. If you've checked your lines then one of the only remaining places to look is in the tank. It's a job, but I thought it was well worth the effort!
Here's the mod I carried out on my other half's surf. As you can see the bracket's been modified a bit! and the primer is now in line and not in the filter assembly as before.
not a bad fix it job, i'm going to see if i can find a way of putting in an inline filter or trap somewhere or on the hose, are one of the hose's for diesel in and the ofther one out do you know?
Do you have a pic of the inline filter you fitted. Where did you fit it and is it easily replaceable or does it use replaceable cartridges? No fuel starvation effect? Many thanks if you get to reply.
Ciao
