For 2" longer springs, what is the length difference between drivers and passenger side?
Also, I believe I need a drop bracket for the panhard rod. Is this correct?
I've done a rad swap, serviced the starter, swapped the timing belt changed my steering idler and done various electrical jobs. Would changing the springs and shocks be within my grasp?
What about raising the front suspension to match a 2" raised rear. Can that be done with the standard torsion bars alone, or will I need to change them?
Pure Genius!!!
