no height modification max tyre size???
  • no height modification max tyre size???
    Hello there, i dont actually own a surf, just a 2.4 92 hilux.
    I want to chuck some bigger tyres on instead of my puddle cutters.
    trouble is i want to get as big as possible (height and width) without havubng to change the current wheels and without having to jack her up.
    (thats all for later, i just need her in a presentable state for now)
    i was told i could get 32's on with no mods, but will they fit these wheels? they seem quite skiny.
    what size tyres can/should i order and from where?
    i have attached a pic of the wheels in question (they came with it, i have no idea if they are the standard ones?)
    Ok so i can run 31x10.5's if i use spacers right?
    doesnt sound too bad.
      Those are the 7" rims if I remember so you should be able to fit 31/10.5/15s on. If it's chunkyness your after, go for Mud Terrains.
        They are standard rims for a pick up . Some are 16" rim , so check before you order your rubber .
