Hi eveyone hope you can help. Does anyone have any ideas on what could be wrong, when i start my surf from cold it will only change up to second gear but when it warms up it will work ok
gearbox
Well the plot thickens??? The garage i took it to phoned me back and said they could not do anything with it because they did not have the correct lead to plug into there computer, so i have it back and it is still the same.
I then tried to do the flash codes to see if i could find the problem but all i got was a light that just flashed and flashed and flashed and flashed and flashed and did not give any indication of a code.
So now i am totaly lost as what to do next.
Originally posted by mattys surfWell the plot thickens??? The garage i took it to phoned me back and said they could not do anything with it because they did not have the correct lead to plug into there computer, so i have it back and it is still the same.
So now i am totaly lost as what to do next.Trust your Hound.
