Finally traced the vibration that i've been suffering to the rear joint on the prop. I took a picture, but it isn't very clear (its broken where the arrow is), and after some searching, found one from Gamedawn which has a bit of a bigger chunk missing. Is the bit that is broken part of the u/j, or do I need to try and source a new prop? On mine, there is only a small bit of metal missing, so it isn't quite as bad as the one in the picture. If I do need a new prop, has anybody got one lying around.
