Hi,
SVA people want me to adjust my brakes on my 94 3.0 Surf,.
The SVA mans comment was;
'The braking ratio of the axles is not,for all values of total brake force less than the friction force ration 9taking account of the weight transfer) between axles with the vehicle in running order. Rear brakes lock before fronts. The brake efficiency with the servo fully depleted and at a pedal pressure of 50kg is less than 30% cgvw'.
Now he might as well have written this in Dutch for all it means to me, but heres the sting. The SVA guy then says, Mr friend can sort this out for you, here's his number. I call 'friend' who says he can sort it but it takes 3-4 hours of labour.
I've asked a couple of other surf owners I know and one has suggested that he solved his SVA brake problem just by fitting hard brake pads (apparently Japs use soft) and adjusting a valve on the back axle.
Can anyone shed any light on this, give me any info etc..
appreciate any help
Thanks
Dave
appreciate any help
Thanks
Dave
