Are all Toyota bolts made of this stuff?
Sheared another one this evening, putting the bumper back on.
So, in 4000 km, we have discovered that:
the battery connectors are made of tin foil
the rear bumper disintegrates
you can't clean the rad because the aircon's in the way
you daren't touch it with a spanner because things snap, despite liberal application of WD40.
Now, the L*ndR*ver may have been an unreliable heap, but in 30,000 miles I snapped only ONE bolt. Toyota beat that in a half-hour sitting!
Is there anything else I should avoid touching? Will the UJ disintgrate when I grease it? The axle drop if I top it up?
Seriously folks, I am severely unimpressed with the engineering. The thing seems virtually unmaintainable. Did I get a bad one, or are they designed and built to be particularly unmaintainable, thereby forcing the user into buying a new one every time a repair is needed?
