My exhaust split on the bend where it goes over the back axle. The rest of it is solid and there is no sign of lose baffles in the front box. I had a new transit diesel exhaust, which someone had dumped round the garages, stashed in case I needed it. One of the bends on the tranny exhaust matches the bend that has split on the Surf.
I have cut the rusty bend out but it is the same dia as the surf one. I had another exhaust off cut which was slightly bigger but not large enough to slide over to make an overlap joint. With a bit of heat from the blow torch and the BFH, I have managed to sweat it on. All I need now is for it to stop raining so I can weld it up.
