Well I've got the vibration scenario at 20mph upwards, especially when towing a trailer. There is play in one of the UJ's, but I was under the impression that if I whipped it off and replaced the UJ then the prop would need to be balanced? If this isn't a case then I'll give it a bash myself.
PS Would you trust Gary and Minty to work on YOUR Surf?
Cheers - Dave.
As long as you keep the the prop in one piece when removing ie dont let the splined piece come off , you can press out the cups of the uj and replace without loosing the balance (in most cases) . Also mark the yokes before pressing cups out so they also go back on in the same place .
