Hi All,
I`m having a problem of rolling resistance- especially after towing. Initially I thought it was because I raised the front too high and it was due to the front driveshaft angles. I lowered the front slightly and it improved things for a while. I did some heavyish towing this week and is now worse than ever.
Could this be the Load Sensing Prop. Valve on back axle causing the rear brakes to bind? I fitted 2 inch suspension springs to a saggy bum a while back but did`nt raise the bracket of the valve to compensate. I`ve just been out to measure the adjusting lever distance and it is within the min. max. limit at 123mm.
Any suggestions?
cheers,
chris
Any suggestions?
cheers,
chris
