Bronze bush
  • Bronze bush
    Ok how do I get the bronze bush out of the hub????? and with what.
    BFH.
    There are 2 cut outs that let you get a nice fat punch on the edge of the bush, through the middle of the hub from the outside of the car, and give it a solid clumping.
    Now, getting the new one in straight is another matter!!
    I have an old outer CV joint that I put the bush over the spindle, then slide it in place from the inside of the hub, and hammer it in. This way it goes in square.
    There isn't a lot of room to swing the hammer. But it works.
      and another trick for getting bushes into interference fit holes is to put the bush in the freezer overnight
      Bogus
      Сви можемо
