just noticed somebody elses post on air conditioning and this jogged my memory of how rubbish mine is dh took it to be re gassed but apparentley the adapter was different to the ones they used at the garage so my question is where can i get it done and how much will they charge?
air conditioning is rubbish where can i get
 Got mine done locally,either take to him or he will come to where you are.
 Last time it was £75:00 to regas her.
 You hear a lot about what you can and can't use to regas the system
 but shop around with the Yellow Pages till you find some one that knows
 what they are at with out charging the earth.
 Hope you get it sorted, my guys in Reading which is to far for you, cheers
 poppy   GOT NO COWBOYS HERE? GOT NO COWBOYS HERE?
 thanks poppy think i will have to have a ring around done a search on air con found loads i think ours is r12 and the reason the adapter was different was because of that i remember dh saying now but he was never told we could get it converted or anything i will have to look into it as my surfs black so attracts the sun bad lol get it sorted before the summer i was roasting earlier when i went out and the sun was only just breaking through the clouds
 Make sure
 HI Missy make sure they pressure test,re-oil before they re-gas to make sure you've no leaks and your pump wont seize up.He should put some green dye in so if you have a leak it will show up with ultra violet.Just had mine done yesterday all in £60.00
 ALZ
 Hi,Originally posted by missyjust noticed somebody elses post on air conditioning and this jogged my memory of how rubbish mine is dh took it to be re gassed but apparentley the adapter was different to the ones they used at the garage so my question is where can i get it done and how much will they charge?
 just had quote from a mobile auto air con guy here, seems a very switched on kiddy,he will re-gas for £45.00, or service the system and regas for £64.00 not a bad price I though so booked him for nexy week ,will come round my house to do it .
 Martin
 over the hills and far away
 missy,
 try these i just looked up 4u...
 service@vehicle-aircon.co.uk
 01656 738505.... maesteg...
 or
 info@airconditioningswansea.co .uk
 01639 795736.... cimla, near neath...
 carl.... gettin coooooler... and dark.... gettin coooooler... and dark....
 make sure the system is completely vac'd first and if your anywhere near the machine have a look at the display, this should show -1000mb any lower than -970 and it's your first indication that there's a problem with your system. then they should add a tracer and oil and re-gas, make sure that they fully regas and don't take the p*ss by only 3/4 gassing, don't remember off hand what the correct amount is, and finally but by know means least watch him carefully when he takes the hoses off after gassing, if he starts sticking something in the connection on your motor to loosen the ball valve, then you're losing gas that you've paid for and I have seen someone even try to get away with on my mates motor, wait for it............................ ....
 filling the caps with silicone before replacing them!!!! to try and stop the gas p*ss*ng out!!! Just beware, cheap don't always be a good thing. Oh and make sure you run the air con regular, a lot of people don't realise you don't have to sit there shivering when you're using it, you can run it with the heater on max if you like, it does what it says, it conditions the air, not turn your motor into an iceland delivery van!!
 Anyone up this end wants their system servicing e-mail I can point you in the right direction if you like.Nihil illigitimi carborundum
 thanks for all the advice will keep a close eye on them while they do it just to make sure they are not botching it ,will take a look at those links as well cheers for that trying to get all the stuff sorted on her now before the summer comes.thanks all
