can anyone help fitted a tow bar from towsure with no problems so far so good until i found the release handle on trailer hits spare wheel when turning right cant lower ball anymore without the trailer being nose heavy yours stuck lyndon
spare wheel in way
Two options here-Originally posted by wildman1can anyone help fitted a tow bar from towsure with no problems so far so good until i found the release handle on trailer hits spare wheel when turning right cant lower ball anymore without the trailer being nose heavy yours stuck lyndon
a) Plan route carefully to avoid all right hand turns.
b) Pop into your local factors/trailer parts shop and purchase an alloy spacer block designed to be bolted between the ball hitch and the towbar.
b) is the preferable option
I had the same problem with my jockey wheel handle hitting the spare wheel cover and cracking it, so I fitted two spacers, one 50mm and one 25mm, which does the job nicely. To be fair though it is only a small 6 x 4 trailer with 500cwt capacity.Keith
fuel filter
do you change your filter and are there any problems in cold weather i have used rape seed but it has been treated with an additive of some sortOriginally posted by BUSHWHACKERSomerfields cheap vegatable oil is rape seed oil, it says so in the 'ingredients'
Perhaps that's why it smells rancid when used in the truck.
If you're gonna be using veg oil a lot, then change the filter twice as often as you would when using diesel.
Colder weather you'll need to thin it down by adding diesel, About 30% veg oil to 70% diesel in the really cold months, opposite ratio in the middle of summer. Unless you have a fuel heater of course, but thats another topic!
Originally posted by BUSHWHACKERIf you're gonna be using veg oil a lot, then change the filter twice as often as you would when using diesel.
hmmmmm does this help the towing problem as well
My 4x4
My choice
Back off
tow bar+fuel
sorted tow bar got some more steel made longer brackets bringing it further out by about 4 inches just got to paint it.its allways good to ask people who are using veg oil rather than people who are guessing or making mistakes myself thanks for help for now .Originally posted by Koihmmmmm does this help the towing problem as well
