Has anyone ever found their starter motor loose ? I noticed a slight knock/rattle after a recent run, which upon further investigation turned out to be the starter motor. The upper bolt was loose (and i didn't check the lower, as i couldn't see that there was one there, but will check tonight...). I'm a bit puzzled, as this hasn't been messed with (ever?) as the starter looks original...
Weird.
Weird.
