Hello friends,
I have just purchased a 1992 K reg Surf 2.4td, its only got 76000 KM (58000 miles) on the clock, I am quite happy with the beast apart from one thing....the 4WD system seems to have an issue. Every time I press the 4WD switch I hear a relay click and there is a clonk noise underneath...but the 4WD light only appears for 1 second !!!
Has anybody got any idea whats wrong? If I remove a vacuum pipe from a little relay/switch under the bonnet (next to the drivers front wing) and then try selecting 4WD the light comes on and stays on, but if I reconnect the vacuum pipe the 4WD only stays on for 1 second please advice
Many thanks in advance
Faz
Faz
