when offroading at weekend, noticed jolting in steering system getting worse.
its not a ball-joint, as checked and repalced all of these (tie-rod ends, pitman arm, idler arm, steering damper, wishbone ball joints).
I have also tried tightening the steering box via top adjustment screw.
its when you are driving over rough rocky ground, you can feel and hear a jolting/knocking through steering wheel as the wheels get pulled to each side by the terrain.
Steering freeplay doesnt seem that bad, and wheels turn pretty much as soon as i turn the wheel.
steering box seems secure to the chassis.
any ideas what could be causing this? as Im sure its not normal!.
