Mot failed due to these little blitters being worn and damaged. So far it's taken me all day to get the outer ball joint off, but I only managed that once I took the wheel off and introduced a splitter and hammer, But I can't get the angle to smack the inner one off....
The biggest headache is the pitman, I can get onto the bolts with a bit of reasonable leverage, but I can bearly get to the nuts on the other side.
Is there a trick to it, would I be better removing the radiator like object thats so coveneintly blocking the way...?
The things we do to save £250
Mac The Wac
