I have a 91 2.4lt T/D surf.. Agian i have problems starting when engine is hot, recently have had fuel pump reconditioned, fuel injectors checked, glow plugs are good, replaced fuel & air filters, It start first go when cold, but when it's hot, it takes a while to turn over with a bit of smoke. Local mechanic not sure as he thought fuel pump should have fixed problem, although it need attention anyway...
Any idea's would be helpful, as i'm stumped...
Thanks...
Thanks...
