3.0 1994 KZN130
I have had e metalic knock on front drivers side wheel. I did find to much play in the front wheel bearing (no bearing noise) but I do have movement in the outer cv joint nose to hub inner bushes. Has anybody had any issues with these bushes or is it normal to have play between outer cv nose shaft and the inner hub bushes. I have stripped this side down and having felt the other complete side it also has play up and down, in and out.
Hope some one sees this tonight as I have one wheel off my wagon.
