They haven't been the same since I first went through the water....
The brakes still stop the vehicle well enough, the problem is that I have to push the pedal an extra 2 inches to get the same effect as before. I couldn't pull the handbrake on at Norfolk because so much crap had got caught in the handbrake cable on the rear axle. Clearing this solved that problem but then I could pull the handbrake all the way on whilst driving down the A11 with absolutely no effect!
I tried reversing and jamming on the brakes (and handbrake) hoping that the rear brakes might adjust themselves properly, which helped slightly (handbrake now works but needs pulling up a bit more). Still have to press the pedal a long way down though. Sounds to me like the pads/shoes are too far away from the disc/drum and I'm having to push the pedal further to compensate...dunno what the cause would be tho. Not lost any fluid yet
I'm thinking my rear drums need stripping down and sorting out properly. I haven't been out to check anything so far as it's too damn cold and dark!
Any suggestions?
Any suggestions?
