Hi All,
After a few hiccups with a recent service I decided to give the cooling system a "real good" flush and refill with some good antifreeze/coolant.
After I ran the motor with some coolant flush that promised to clean the system I drained the system until no more dirty stuff came out and stuck a hose into it, drained again and half an hour later I replaced the coolant.
Although it says that the cooling system takes 9 litres I only managed to get 5.5 litres back in!!!!!
I reckoned there must be some water left in after the flush, plausible?
The heater is very poor now in comparison to before!
Ah haa, I thought!, I have an airlock!, no problems!
A drive up and down the street, squeezing the pipes etc. did not lower the level of the coolant at all!
If I start the car from cold the level stays the same and when the car heats up it pushes the cooland out!!!!!
I guess the airlock must be in the heater matrix, right?
Anyhow, when I searched the forum on tips how to get rid of airloack I found this:-
Burping
I CANNOT UNDERSTAND IT AT ALL!
I must be dumb because it is double dutch to me!
Can anyone explain this or show me where to attach the pipes, pictures would be good, I am handy with a spanner but this is way over my head!
Can anyone explain to me in simple terms how to burp the cooling system, PLEASE?
Thanks!
Gary
Burping
Thanks!
Gary
