speakey
  • speakey
    My turbo light does not come on but the check light is on, any ideas please
    hiya mate try and use the search button at the top of the page you will get lots to look at.
    also try searching for error codes and how to check them.
    best of luck
    Tim
      Check that your air temp. sensor is plugged in.............
        speakey
        I will cheers
          At bottom centre of the above pic is the Turbo Pressure Sensor. Check the hose for this is connected. It runs from under throttle body to the white filter and then to the sensor. Very common for this hose to fall off because of deterioration or even have a hole or be split.
