Wiper Linkage Help
  • Wiper Linkage Help
    Hi i have a 2nd gen 1991 2.4td and the drivers windscreen wiper is not working and i think i will need to replace the linkage, i am at present using only the left wiper, which is turned up to clean most of the screen.
    Question how do i get to the bugger and is it an easy job to remove to fix.
    Cheers for any advice
    I presume you've checked the tightness of the nut on the drivers wiper? Sounds like something has become detatched or loose on that side.
