does anyone have a wiring diagram for the electrics for the 4x4 side of the surf please ...... no light on dash and does not engage into 4x4 but can hear a relay clicking when i push the button any help would be great ... cheers
4x4 not working
Originally posted by gruntdoes anyone have a wiring diagram for the electrics for the 4x4 side of the surf please ...... no light on dash and does not engage into 4x4 but can hear a relay clicking when i push the button any help would be great ... cheers
have you tried going forwards a bit then backwards to try and engage the 4wdhttps://www.facebook.com/groups/henpals/
Originally posted by laser_jock99Check for loose vacuum hoses on the actuator- seems to be a 'popular' fault.
Try putting it into 4WD low with the small lever. That will at least confirm whether or not the 4WD is working. If it does go in and works then it's probably just "stuck" in 2H if it's not been used for a while. Had that with mine back in Dec when we had the snow down here. Thought it was "fubared" in mine but after I'd put it in 4L it then worked fine in 4H.Mike G
Originally posted by TallymanTry putting it into 4WD low with the small lever. That will at least confirm whether or not the 4WD is working. If it does go in and works then it's probably just "stuck" in 2H if it's not been used for a while. Had that with mine back in Dec when we had the snow down here. Thought it was "fubared" in mine but after I'd put it in 4L it then worked fine in 4H.
had it checked out this morning by a sparky .. the 4x4 controll box is knacked .. if any one can help with a spare one let me know asap .. please .. its the small black box behind the pannel in front of the gear leaver .. needs to be for a 1993 2.4 turbo dont know if any other model would do .. cheers
Originally posted by grunthad it checked out this morning by a sparky .. the 4x4 controll box is knacked .. if any one can help with a spare one let me know asap .. please .. its the small black box behind the pannel in front of the gear leaver .. needs to be for a 1993 2.4 turbo dont know if any other model would do .. cheers
Jon 07740 337153I'm a custard donut monster
right guys.. fitted replacement 4x4 controll box and still the same AAAAGGGHHH .. press button on leaver and the relays click in controll box .. no light on dash (bulb ok) no 4x4 and no power to the solinoids on the off side inner wing?????? has anyone got a wiring diagram for this or any help would be great...
I can only find this at the moment, I'll search a bit more................
http://www.toyotasurf.asn.au/techsite/add.htm
