My 2.4 Has Developed An Engine Knock ? Its Ok On Tickover But When It Is Reved When Stationary Theres A Rapping Sound Like Big Ends Or Crank? Is This A Fault With The 2.4. It Does Not Overheat? But Does Smoke Slightly, The Engine Has Done 105 Km Regards Paul .{ 1992 2.4 Surf }
Engine Knock ? Help
did you get this motor from a dealer? you seem to be having too many probs - if from a dealer sounds like you need to back it for them to sort!- I dont know about redress if it was a private sale....but I bet there is someone....Originally posted by shakeytitsMy 2.4 Has Developed An Engine Knock ? Its Ok On Tickover But When It Is Reved When Stationary Theres A Rapping Sound Like Big Ends Or Crank? Is This A Fault With The 2.4. It Does Not Overheat? But Does Smoke Slightly, The Engine Has Done 105 Km Regards Paul .{ 1992 2.4 Surf }
Tony
I BOUGHT IT PRIVATE AND SOLD AS SEEN? I GOT IT CHEAP SO I DONT MIND SPENDING SOME MONEY ON IT AS IT WILL MAKE A NICE VEHICLE WHEN I IRON OUT ALL THE FAULTS,, THANKS PAULOriginally posted by fatfiresdid you get this motor from a dealer? you seem to be having too many probs - if from a dealer sounds like you need to back it for them to sort!- I dont know about redress if it was a private sale....but I bet there is someone....
Ok there you go, you pays your money.......Originally posted by shakeytitsI BOUGHT IT PRIVATE AND SOLD AS SEEN? I GOT IT CHEAP SO I DONT MIND SPENDING SOME MONEY ON IT AS IT WILL MAKE A NICE VEHICLE WHEN I IRON OUT ALL THE FAULTS,, THANKS PAUL
I believe stevo is your man in those parts op north as they say, perhaps you need a word with him - hope you can get it sorted.
My horendous knock was a pot slapping about
but mine is a 3.0L - sounds like a possible head off to start
Tony
THANKS WOULD YOU HAVE STEVOS CONTACT INFO ,, MANY THANKSOriginally posted by fatfiresOk there you go, you pays your money.......
