Hey my surf now starts and its freezing here, the glow plugs have been changed and i did more mechanic type adult fixing than ever before ..well chuffed.
Didnt know how to check which were gone so changed all 4 as they only £5 each from milners
Even had to buy new Jubilee clips and a 12mm deep socket but it is now sorted and i even got to get oil on my hands .
Many thanks for the help and advice
Anyone going to do this job make sure you have a 12mm deep socket , a spare couple of jubilee clips, (and i would buy a new set of the insulated screws that cover the plug and screw onto the bus bar) as they seem to snap and crack and are a ceramic/plastic type thing with a brass screw inside and are a **** to remove.
I ended up having to take off the plastic trunking attatched to the air filter and the metal one that has EFI written upon it to get to the plugs.
