Help Please or at least some advice !!!!!!!!
I have attempted to change my glow plugs and have taken off the trunking that leads to my air filter and then removed all but 1 of the ceramic/brass screws that hold down the bus bar.....................the first one towards the radiator came off fine and the 3rd and 4th came off with minimal damage to the ceramic However number 2 which is underneath the part which has EFI written on it is broken down to the brass and i cannot get any grip on it!!!
Am i going to have to remove said metal trunking with EFI written on it and if so how ? Or will i be able to finally get to the plugs and not be able to remove it anyhow as there doesnt seem to be the angle to lever it out.
Still at leawst its only just above freezing and my wife was
due 2 days ago and i need the car for the hospital run....i know daft and irresponsible HELP PLease
