ive just had a new head from stevo and the head seems good only problem im having is engine is running to cold i should point out this head wasnt fitted by stevo and in no way am i slagging him or his product just wondered if anyone has had the same fault my surf is now struggling to get warm no matter how long i run it for if i run it up a steep hill it gets half warm but soon cools down i was supplied an 82 degree thermostat with the head and stevo talked my mechanic through the adjustment of the viscous fan so my question is ...? is it likely to be the fan adjustment the thermostat an air lock or a combination of these factors
ne head from stevo and problems
head
Mat are you sure they have fitted a t/stat ?, sounds to me like there is no stat fitted or the stat is stuck open for some reason. The combination of an 82 deg stat and viscous fan adjustment certainly helps the car run cooler but not as cool as your'e describing.
Cheers, Steve.
Maybe they over adjusted the fan, is it locked up completely, you can can hear it 'roaring' all the time if it is.
Originally posted by matthew coventryive just had a new head from stevo and the head seems good only problem im having is engine is running to cold i should point out this head wasnt fitted by stevo and in no way am i slagging him or his product just wondered if anyone has had the same fault my surf is now struggling to get warm no matter how long i run it for if i run it up a steep hill it gets half warm but soon cools down i was supplied an 82 degree thermostat with the head and stevo talked my mechanic through the adjustment of the viscous fan so my question is ...? is it likely to be the fan adjustment the thermostat an air lock or a combination of these factors4x4toys.co.uk - Keeping you on and off the road...
GOT NO COWBOYS HERE?
