Maybe I am am wrong! https://www.google.com/search?q=8856...zbn37M&vssid=l
Cabin air filter? Where?
Originally posted by kingroon View PostEpic Thread Revival.. 20 years later, but I was searching on how to replace the Cabin Filter, and this one came up..
So, thanks for the direction.. Glovebox removed, I believe this is the Filter in the Photo below..?
Leave a comment:
Leave a comment:
Originally posted by UplanderHi,
Howard Hughes rides again, eh ? Like it, cabin filters hahahahahahahaha ! still if u live in cumbria maybe u need them, wherabouts are u, i used to repair boats in a big shed near whitehaven, lived in lorton...edge of lake d..
peter
Hi Peter I basically live in Whitehaven! You need an air filter round here thats for sure. The fan does not seem that powerful so I thought it was blocked with 12 years of dirt!
Leave a comment:
Originally posted by WhelanHi can anyone tell me where the cabin air filter is? Had a quick look round but seem to have overlooked it!
Cheers Tom
peter
Leave a comment:
Originally posted by WhelanReally? so the air is just direct from outside?
Neville
Leave a comment:
Its behind the glove box... but when you see it, you won't call it an air filter... more like a manky piece of foam...
If you remove the glove box, you will have easy access to it... very carefully remove it, and wash it in warm slightly soapy water... and dry it very carefully, not much heat... then spray with those odour spray things that are going around at the moment... (Fabreeze...?)
As for the one in the roof... good luck with that. Its a paper element in a plastic cartridge... no part numbers, no description... Tried to bodge a new element after breaking the plastic cartridge apart... does work after a fashion.. but the rattling fan is driving me nuts...
Leave a comment:
Originally posted by MorrWhat Cabin air filter??? I don't believe any Surfs have em, except perhaps those with the optional box in the centre of the roof.
Leave a comment:
Cheers Tom
Leave a comment:
Cheers TomTags: None
Leave a comment:
