Recently my 1993 2.4TD ssr-x surf has started making a light squeak/squeal when the clutch is lifted (foot on the pedal). It does not matter if it is in neutral or in gear for the noise to occur. When the clutch is engaged (foot off pedal) there is no noise at all, even in gear and cruising. Could this be a thrust bearing? The clutch has a good bite that is not at the end of the reach of the pedal. I have not checked the hydraulic fluids for the clutch, so I will check that tomorrow.Any ideas/opinions would be great!
Cheers Tom
