Recently my 1993 2.4TD ssr-x surf has started making a light squeak/squeal when the clutch is lifted (foot on the pedal). It does not matter if it is in neutral or in gear for the noise to occur. When the clutch is engaged (foot off pedal) there is no noise at all, even in gear and cruising. Could this be a thrust bearing? The clutch has a good bite that is not at the end of the reach of the pedal. I have not checked the hydraulic fluids for the clutch, so I will check that tomorrow.
seriously, sounds like a case of thrust bearing in need of replacement, trouble is whilst your goin to that level of dis-assembling, your probly as well to do the clutch aswell. mines been noisy since i got it, but unless it starts sounding really rough (like its about to spit out bearings and then sieze!) my intention is to leave it as long as i can and get both done at same time. its a question of tollerance on your part!
..in my case the thrust bearing is one of many rattles/whines/sqeeks, they add character!
VW Taro (hilux single cab PU) - 31" rubber, H/D springs and shackles, LSD, 4 pot front callipers, 2.4 N/A Flymo engine..
Cheers for the comments its not that bad at the monmet. I have been trying to solve all the squeaks and rattles but this one is going to have wait! Well I will not worry about it yet, clutch seems to have plenty of bite.
Cheers Tom
Hi,
Seeing as your in Cumbria, unless you got a nice warm shed to work in (big enough for the car as well) I wouldn't wait too long....imagine if your clutch failed in say, January....or maybe you like being on your back in a snowstorm...
