Fitted one of these last night, only minor problem was getting bolts into cross memeber for new bracket, but a crowbar helped to pull cross memeber down to fit them.
Then kit was missing 2 nuts and bolts for one of the U-shackes...
but got that sorted.
I notice steering is a bit heavier now at slow speeds,
it has cured the shaking on truck, but has really reduced it, so not so annoying.
Last year I fitted a new standard damper from milners, that made no difference. I reckon I could ahve left the standard one on the truck, and fitted the ES2000 - but would probably strain the steering pump with 2 dampers on steering!
I suspect steering box is knackered, as clonks even when adjusted. And if i adjust it too much it then binds. Most noticeable when offroading on rought stoney tracks and going down hill, as steering shifts from side to side can feel something loose in steering box through steering wheel.
Have replaced all other balljoints in system!
